Need help in the following task. Simple assembly containing square Plate and a Rib (Angle bar) placed (welded) over on top.
Plate has a window which varieties by size and position on the Plate. Then I make Rib pattern to cover whole Plate with Ribs. Number of pattern components (Ribs) can vary.
Next I make RibCutSketch linked to the window and Exstrude (cut) on the assembly through the Rib Pattern. Up to this point it goes fine.
But when I change position of the window or /and number of ribs it does not cut new pattern members. I have to add them manually «Add Participant».
Would appreciate any help in programming this task either via iLogic or VB Macro.
Thank you in advance,
Alexei
