Inventor General Discussion
Member
Meneely
Message 1 of 6 (677 Views)
Custom content center parts not updating Inventor 2012
677 Views, 5 Replies
11-05-2013 09:46 AM
I've created a custom content center for the company I work for so we can store all our standard parts in it. I'm still in the testing phases of this library and I don't have a strong understanding of how it works exactly. I've made it a desktop content, and I made all the parts as iparts and published them that way. Now when I go back to that iPart and make a change it doesn't update. I've used the refresh buttons under the manage tab and in the editor and still no update. My goal is to be able to update the part if any revision comes back, and still have the standard part update in all assemblies it's placed in, if that's possible
Curtis_Waguespack
Message 2 of 6 (671 Views)
Re: Custom content center parts not updating Inventor 2012
11-05-2013 09:52 AM in reply to: Meneely
Hi Meneely,
Have you re-published the iPart after the change?
I think if you go to the Tools tab > Application Options button > Content Center tab, you'll find a Refresh out-of-date standard parts during placement option that should help with your goal of updating standard parts after making a change to your custom Content Center part and re-publishing.
This link might help as well:
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-E51965B6-C931-4A45-BF32-7E456786136A...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
Meneely
Message 3 of 6 (661 Views)
11-05-2013 10:34 AM in reply to: Curtis_Waguespack
Thank you for the reply.
I set the box to refresh out of date content, however it still didn't update. I'm Thinking i would need to re-publish the iPart but i don't know how to do that. I tried to use Replace Family Template while in the content center editor and i recieve an error message saying Import Part Invalid.
cbenner
Message 4 of 6 (651 Views)
11-05-2013 11:10 AM in reply to: Meneely
To do this you need to open the part from Content Center, pick any instance of your family, make sure you check "As Custom".  Save the part somewhere that you can work on it and make ytour changes.  Then go back to the CC, and use the Replace Family Template... pointing it to this most recent part.
I've found that once a part is published, the original ipart is almost useless.  I keep them around in case of catastrophic failure, I could start over fresh.  But for the most part, when i make changes to CC parts, I use the method above.
Hope this helps.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Member
Meneely
Message 5 of 6 (643 Views)
11-05-2013 12:25 PM in reply to: cbenner
Alright, Thank you. I was hoping i could change the iPart and it would update the content center files with it.
cbenner
Message 6 of 6 (629 Views)
11-05-2013 01:02 PM in reply to: Meneely
Nope, afraid not.  Once the part is published there is no direct link back to the ipart.  You can change the ipart and republish it, then delete the old family... but I've found this method to be cleaner and quicker.
ChrisB
