I'm currently using Autodesk Inventor 2013. The main bend I'm trying to achieve is the back bend (curved flange). I have in the past managed to create the side bends just fine but the back flange just doesn't convert to sheet metal to allow a successful flat pattern.
Any help would be great!
This is very poor modeling technique.
Sketch1 is not constrained and this line isn't even horizontal?
You might read this document
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
And I would use all sheetmetal tools to create the part.
Thanks but I wasnt worried about sketch constraints at this stage as it was a quick model for a quick solution - maybe this was a bad idea. I have now attached a fully constrained sketch.
Through 11 or 12 years of experience I have found that my fastest modelers always worry about this stuff right from the beginning. So there is nothing saved in an undisciplined technique based on the experience I have seen.
You have a number of dimensions that don't make sense to me as manufacturable/inspectable.
If you can fix these to what you really want then I can show you how I would model the part.
(my solution will be 3 simple features, one of the three will actually be a mirror of the second feature)
