Is there a code that will create multiple sheets from an assembly? In other words, I want to take an assembly and place a view of each part on a seperate sheet under the same IDW (that we call cut sheets) automatically. Example given shows item 1 & 2, these where manually inserted and diminsioned. I realize that I will have to diminsion and place any call outs, but if Inventor could automatically create the sheets from the BOM and lay down the views, it would be a great time saver, as many of my assemblies will have 50 - 100 cut sheets.
Inventor Tooling will automatically create sheets, not sure if that functionality is in any of the other versions.
