I want to create actual thread through Autodesk Inventor any idea. I anyone one has ipt. file pleas provide. Remember I am using Autodesk Inventor 2010.
Solved by JDMather. Go to Solution.
see this link for an example:
http://forums.autodesk.com/autodesk/attachments/autodesk/78/348727/1/0_50-20UNF%20-%20Hex%20Nut.ipt
Here are some videos that may help also:
http://www.youtube.com/watch?v=cfsT-IYW5kY
http://www.youtube.com/watch?v=Cby_Dw6-wjE
http://www.youtube.com/watch?v=0jV3Ns_HYRc
...and pdf example (written for a different CAD program - but with the previously attached ipt you should be able to figure it out.
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%204.pdf
I have completed creating actual thread with the suggestion from all of you. If any one wants to create the same visit the link below.
