Inventor Forum
Creating a 3d solid from two lofted surfaces
3 REPLIES 3
tmccar
1195 Views, 3 Replies
What is the best way to create a solid "wedge" that is based on a lofted surface between the vertical and horizontal radii shown? I have tried the "loft" option but it will not create anything unless I set the output to surface.
3 REPLIES 3
JDMather
in reply to: tmccar
For future reference - you have posted a huge (2Meg) bmp file that could have been posted as a tiny png image file.
Many people do not have fast internet connections or have monthly limits on downloads.
Attach the *.ipt file here.
Even if surfaces ends up being the solution - simply Sculpt or Stitch to solid.
CCarreiras
in reply to: tmccar
Hi!
So, you create the surfaces with loft (The top one)
Then use the patch tool to create the other 2 surfaces (Front and Base).
Then use stitch the 3 surfaces. Stitch 3 closed surfaces results in a solid. That's it!!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
tmccar
in reply to: CCarreiras
That works, thanks. Sorry about the huge image.
