I am trying to create ADSK file for an assembly created in Inventor so that I can export it to Autodesk Revit. How can this be done?
Solved by pcrawley. Go to Solution.
Inventor version?
Use the BIM exchange button on the environments tab.
I can't remember if you can do it from 2012. You can certainly do it from 2013 and 2014.
Typically the workflow is:
And that's about it. 2014 is better for this workflow because there are some nice simplification tools, but I'm fairly sure it works OK from 2012.
(Just remembered: For ADSK you don't need to simplify in the Part file - that's just for .RFA files which can only be created from 2014.)
I am using Inventor 2014 to create ADSK files for use with Autocad Plant 3D. It works great, but there are a couple of issues that I have found.
I cannot change the transparency of the part in Autocad Plant 3D. I am using Autocad Plant 3D 2015, but perhaps this is not an issue with the latest version. The reason for using ADSK files with Autocad Plant 3D, was to make the importing of 3D models from suppliers easier. The ADSK files work better than FBX files in Plant 3D.
David
