Inventor General Discussion
Active Contributor
kabindrabhattarai
Message 1 of 6 (344 Views)
Creating ADSK file.
344 Views, 5 Replies
10-02-2013 12:43 PM
I am trying to create ADSK file for an assembly created in Inventor so that I can export it to Autodesk Revit. How can this be done?
mcgyvr
Message 2 of 6 (331 Views)
Re: Creating ADSK file.
10-02-2013 01:44 PM in reply to: kabindrabhattarai
Inventor version?
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Contributor
kabindrabhattarai
Message 3 of 6 (328 Views)
10-02-2013 01:49 PM in reply to: mcgyvr
I  am using Inventor 2012
Active Contributor
kabindrabhattarai
Message 4 of 6 (298 Views)
10-03-2013 12:18 PM in reply to: kabindrabhattarai
Help. Anyone? Please?
mcgyvr
Message 5 of 6 (287 Views)
10-03-2013 01:00 PM in reply to: kabindrabhattarai
Use the BIM exchange button on the environments tab.
Windows 7 64 bit
Distinguished Mentor
pcrawley
Message 6 of 6 (272 Views)
10-03-2013 05:29 PM in reply to: kabindrabhattarai
I can't remember if you can do it from 2012.  You can certainly do it from 2013 and 2014.
Typically the workflow is:
  • Create an assembly.
  • Derive the assembly into a part file (or use Shrinkwrap)
  • BIM Exchange (should be on the Inventor ribbon under "Environments" I think)
  • "Export Building Components".
And that's about it.  2014 is better for this workflow because there are some nice simplification tools, but I'm fairly sure it works OK from 2012.
(Just remembered:  For ADSK you don't need to simplify in the Part file - that's just for .RFA files which can only be created from 2014.)
Peter
