Inventor Forum
Create flat pattern idws from an assembly
1 REPLY 1
1074 Views, 1 Reply
To increase the speed of production, I like to generate idws of flat patterns from assembly. The following iLogic rule work fine inside a metal sheet (I had to create flat pattern before run this rule).
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc As DrawingDocument
Dim oPartDoc As Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oView1 As DrawingView
Dim oOptions As NameValueMap
	oPartDoc = ThisApplication.ActiveDocument
	oDrawingDoc = ThisApplication.documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2011\Templates\Standard.IDW", True)
	oSheet = oDrawingDoc.Sheets.Item(1)
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oOptions.Add("SheetMetalFoldedModel", False)
	oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(15#, 15#)
	oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1/5#, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oOptions)
 But from an assembly there are some problem ( firstable I'm not an expert of vba and ilogic)
fmgr = ThisApplication.Filemanager
For Each file In fmgr.files
doc = ThisApplication.Documents.ItemByName (file.fullfileName)
compdef = doc.ComponentDefinition
' For each assembly or subassembly
'If (doc.documenttype = 12291) Then
 For Each occ In compdef.Occurrences
' For sheet metal or part
    If (occ.definition.type =83886592) Then
'	If (occ.definition.Subtype ="{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
		Dim oSheet As sheet
'		MessageBox.Show("test1")
'		Else
'		MessageBox.Show("test2")
    End If
 Next occ
'End If
Next file
 Can someone help me?
1 REPLY 1
skyngu
i guess you have to open sheet metal part before create its drawing document.
Autodesk Inventor Professional 2019
