Hi there,
I've imported an IGS file into Inventor and now want to create an explosion view of it. I've done this several times from assembly files but I don't know how to proceed with this importet geometry, since I can't import the model into a presentation file. Is this even possible?
Thank you in advance,
Max
Attach your file here.
it's sadly not a multibody. I can select different surfaces but that thing is just a solid piece of rock, containing no part information whatsoever.
Unfortunately due to my lame internet-connection, I can't upload the file here. 56K isn't any good.
Max
You have composite surface bodies.
You will need to convert to solid bodies and an assembly.
