Inventor Forum
Create an angled hole in assembly
1 REPLY 1
255 Views, 1 Reply
Hi!
Im new in Inventor and I have a problem with creating a hole through two parts beacause they are a bit angled.
Im creating the holes part by part and Im using the work point method.
But unfortunately this is the result:
Im wondering if there is any other methods so I can get the holes coinciding?
Thanks!
1 REPLY 1
JDMather
Question 1.  When will then hole features be created in the real world, at the part level before assembly of the parts or after assembly?
Usual process - create hole in one part at the part level (usually with a sketch Center Point located Hole feature).
Then edit the second part within the context of the assembly and Project Geometry for hole location in second part to match first part.  This creates an Adaptive feature which might not be best for a beginner.  The alternative is to edit the second part and locate a non-adaptive hole.
Another option would be to use multi-body solids techniques and push out the individual solids when done.
Another option would be to use Derived Component techniques.
Another option would be to edit one part in context of assembly and Copy Object....
Another option might be a "match machining" operation where  the holes are created at the assembly level.
In some cases using the Bolted Connection Design Accelerator would be the best option, but doesn't sound like that is the case here.
My guess is that your best bet is to attach the files here for suggestions.  Inventor is a professional program and deserves (requires?) a professonal level of prepartion.  The design intent is critical to choosing the best technique.  I almost never use the Work Point method of placing hole features.
