Inventor Forum
Create a spline with given points
4 REPLIES 4
fce
1991 Views, 4 Replies
I have a group of Points coming from a step.file. So I dont have their coordinates, excel list or anything else. Just the step file. Around 100 points. There is a line between each 2 consecutive points.
Is there any way to select all the points and create a complete spline?
Or even to select all the points and create tangent arcs between all of them?
I am not sure how it can help but I send a print screen of the points.
Best Regards,
Francisco Vaz Cerqueira
Tags (1)
4 REPLIES 4
CCarreiras
in reply to: fce
Hi!
I thinks it's impossible... i could inventor know the points sequency to join in a spline?!
You have to pick the points one at time and in the correct sequence.Smiley Frustrated
If your curve has a math formula, try to use the "equation curve" tool.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
fce
in reply to: CCarreiras
Hello Carlos C,
I thought something would be possible since the step file has an origin. So the points could be defined relative to that.
Until now only one situation occured in which I needed the spline and I had to do it like you said. One by one in the correct sequence.
But in the future I will have to do it to other groups of points.
I do not have the equation formula as well. I will try to define an equation for it. If not I guess I will have to do it the patient way, as you said.
Thank you for your help,
Best Regards
JDMather
in reply to: fce
Keep in mind that more points DOES NOT equate better curve.
I will wager that I can create a better curve, well within whatever the manufacturing tolerance is, with fewer than 10 points (I'm guessing with only 3-5 points).
fce
in reply to: JDMather
I did so. With 5 curves, I obtained a max difference of 0,3 mm, which is more than fine. This solves part of the situation.
Still I would like to have it as a spline because in the assembly there is a bearing sliding along all the curve. And I dont think I can make the bearing slide along several consecutive curves. Is there a way to do so?
Best Regards
