Inventor General Discussion
mbus0013
Message 1 of 12 (2,084 Views)
Accepted Solution
Create a roller chain
2084 Views, 11 Replies
04-30-2012 06:11 AM
I am trying to create a roller chain as part of a cad drawing of a bicyle.
I created a link of the chain (pic attached) and I am following this video to repeat it as a rectangular pattern : http://www.youtube.com/watch?v=DiBGYdbBPHo
However the links are not following the path they're supposed to - sorry I can't attach that file right now.
Anything that I should do different from the video?
Anything that you can think to point out would be helpful. I have been using inventor for a little while but I've never used the adaptive stetches or the functions thing ot a rectangular pattern that is not in the shape of a rectangle.
*Expert Elite*
JDMather
Message 2 of 12 (2,076 Views)
Re: Create a roller chain
04-30-2012 06:25 AM in reply to: mbus0013
I think it would be virtually impossible to see where yours is going wrong without your assembly.
For information on curve driven patterns you might see this document
http://home.pct.edu/~jmather/skillsusa%20university.pdf
...then attach your assembly when you can.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
mbus0013
Message 3 of 12 (2,061 Views)
04-30-2012 07:32 AM in reply to: JDMather
this is what is looks like so far
Is there any way to make the 2 parts of the chain rotate about the pin? It's acting like it's fixed while it's not.
*Expert Elite*
JDMather
Message 4 of 12 (2,054 Views)
04-30-2012 07:34 AM in reply to: mbus0013
I am not familiar with editing image files in Inventor (but it doesn't look correct).
Attach your Inventor assembly here.
mbus0013
Message 5 of 12 (2,043 Views)
04-30-2012 07:43 AM in reply to: JDMather
i tried attaching but i can't attach it as a zipped file and there are too many files used in the assembly to upload one by one
mbus0013
Message 6 of 12 (2,035 Views)
04-30-2012 07:50 AM in reply to: mbus0013
i had already found that - however when i open it I don't see any chain - how do i edit it?
printscreen attached
*Expert Elite*
JDMather
Message 7 of 12 (2,034 Views)
04-30-2012 07:51 AM in reply to: mbus0013
There should only be 3 files.
the path
one link
the assembly file.
If you can't attach here then send me the assembly - jmather_at_pct_dot_edu
mbus0013
Message 8 of 12 (2,024 Views)
04-30-2012 08:14 AM in reply to: JDMather
why is a helpful reply gone?
I am trying to use the chain found here: http://www.cbliss.com/inventor/Parts.htm
What other values shoul I edit in the excel sheet, anyone knows?
Doug_DuPont
Message 9 of 12 (1,995 Views)
04-30-2012 09:56 AM in reply to: mbus0013
You need to drag the end of part marked all the way down. Then the chain will be there.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
mbus0013
Message 10 of 12 (1,981 Views)
04-30-2012 10:29 AM in reply to: Doug_DuPont
Yes it worked!
Thank you.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
