Hello all you Inventor geniuses!
I'm having quite a problem dimensioning a part I have created. I have two sets of circular patterened holes that are displaced from the center of a large disc. I would like to be able to use the Centered Pattern tool, but I cannot without a center point or hole, which does not exist. Any suggestions about how to create a Centered Pattern in this case? I have attached both the part and a sample drawing for clarification.
Thanks guys!
Becky
Aha! Thanks John! I tried to follow some steps I saw on a different set of instructions on the forum that weren't very clear, and didn't realize I could include the Work Point into my drawing. Perfect! Thanks so much.
