Yannick,
Please do not be offened. I am not an autocad user. I can not afford it. I am using a less expensive CAD program that can import DXF, DWG, IGES, WMF, HPGL, and XYZ file types. Do you know if the Archmedes screw pattern that you provided as an IPT file type can be obtained in one of the file types that I am able to import?
Colnel B
Hi
I don't think you will able to import the file and keep the flat pattern. it will be a dump solid with no parameter like the ipt file
