Inventor Forum
Couple more newby questions
21 REPLIES 21
Message 1 of 22
537 Views, 21 Replies
There has been a few references here about the relative merits of iParts vs.
library parts. Anyone want to elaborate on the rational behind this
(hopefully, briefly).
Maybe my second question answers the first:
I insert a library part (finally figured out how, bit dense sometimes), say
a 1/4-20 nut.
Oops, should have been a 1/4-28. How do I change it? I know I can replace it
but that seems a bit cumbersome. Should be easier but I can't figure out
how.
Ray
21 REPLIES 21
Message 21 of 22
With iParts just select the flat head factory part.
Lester Martin wrote:
> How do you change from a Hex head Bolt to a Flat head.
> "Kent Keller" wrote in message
> news:DC9EA8E68C04B4E79B29667242E73FE2@in.WebX.maYIadrTaRb...
>>Select one
>>Edit >>Replace All
>>Browse to the same Parent they are made from, and then in the iPart dialog
> select a
>>different size.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4403 w/registry update
Dell UltraSharp 19" LCD
Message 22 of 22
I don't know of any way, but then I don't use the built in library much.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Lester Martin" wrote in message
news:10972AA7A0103D98B15AA90D29A7D69B@in.WebX.maYIadrTaRb...
