When using the Hole tool in Inventor 2011, there is no clearance hole for the fastener type of Flat Head Socket Cap Screw available. There is Flat Head Machine Screw (82), but this type of screw has a smaller head diameter. Content Center has Flat Head Socket Cap Screws, but using the Flat Head Machine Screw (82) clearance hole will make a countersink that it too small, and when constrained, the head of the screw will stand proud of the surface rather than flush. (See attached reference)
As a workaround, I added the Flat Head Socket Cap Screw to the Clearance.xls file in design data, and used the max. head diameter of the theoretical sharp per Machinery's Handbook (ANSI B18.3.) This works just fine.
I know this issue has been brought up here before (http://forums.autodesk.com/t5/Autodesk-Inventor/Bolt-heads-not-flush/m-p/1925341/highlight/true#M246...), and others, and I'm curious if this is an issue for many people in the community. If so, can Autodesk add the data so we don't have to customize the clearance table to support a content center fastener?
Dave
Solved by mcgyvr. Go to Solution.
been a minor issue for years now.. Autodesk hasn't addressed it yet..
Most of us have simply done what you did and edit the excel sheet and moved on...
