For some reason when I copy line work from AutoCAD and try to paste into an Inventor sketch it does not paste. It acts like it pastes but the line work is no where to be found. Can someone help.
Thanks Robert
That didn’t work either for me. I am able to select the ACAD tool then I select my AutoCAD file I want to import but the Layers and Object Import Options Window does not open at that point. Because of that I do not have the option to select Finish. Do you know why this might be happening?
I did try it on another coworker’s computer and it works fine for him.
Robert
HI!
Try these:
Aditional information:
Even if you can't view the document, you can always go ahead and import all document.
Another "power tool" is using the "constrain end points" and, if the gerometry isn't very complicated, you can also check the "apply geometric constrains". Be aware, if the geometry is complicated, this last option will consume a lot of time.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hi Calavetta123,
Have you compared the service packs that your coworker has instalelled to those you have installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?id=2334435&linkID=9242019&siteID=123112#section17
Also see this link which indicates a user profile issue:
I hope this helps.
Curtis
