I have a lot of notes in an Inventor 2013 file that I need to paste into an ACAD file, so I do not have to retype all the notes.
I tried, but I never get the paste option in ACAD2013.
Can someone help out? I thought this would be simple, or I am missing something.
Yes, How do I get it into the text editor?
I edit the text in the Inventor file, open acad, right click but no option to paste.
Got it!
Thanks a lot
You could also right click on your drawing file (in windows explorer) and go to open with ACAD. You might have to explode the text before copying. This might be faster if you have a lot of text boxes to copy.
Yeah
I forgot to mention that its Inventor IDW to acad DWG.
Where I work we save all our files as Inventor DWG’s. Sometimes I forget that people use IDW’s.
This might be a stupid question but why would you want to save your file as an IDW? As far as I know the only advantage to an IDW file is the size is a little bit smaller. Does it have any advantages working inside Inventor?
The advantage of an Inventor DWG is that it works well with AutoCAD.
I guess the real questing is am I missing out on something because I save my files as Inventor DWG?
IDW is the default native file from the start. The ability to save as a DWG was added somewhere around release 9.
I have been using Inventor since R5.3 and have just become accustom to saving as IDW. Never saw any benefit in saving as DWG. I want to see which files are Inventor and old ACAD which we rarely if ever use for new design. Its just there to support legacy files.
One advantage of saving as DWG is you can open the drawing directly in AutoCAD. You can't edit the views in AutoCAD but you can add details. If you have typical details saved in old ACAD drawings it is usually much faster to add them in this way than to try and import them into Inventor (I'm guessing the experts are going to wince at this!)
When you reopen the drawing in Inventor it will come up with a warning message but ok it and the details will come in fine. NB: You can't dimension from anything added in ACAD
