If you are going to hit Alt + RMB why not just click C for circle or L for
line.
R8 offers customizeable hotkeys as well.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Duncan Anderson" wrote
in message news:DC2C64E701EE73C78CE56C41B30DB883@in.WebX.maYIadrTaRb...
> The only co-ordinate I use is 0,0 via the Precise Input toolbar.
> I wish Repeat Last Command was on the RMB context menu - as with Acad.
> I also wish there were more functions on RMB, such as drawing a circle,
drawing
> an arc and the other main functions. If it means having Alt.+RMB, Ctrl+RMB
> Ctrl+Alt+RMB then so be it, but a lot of us are already familiar with this
> functionality.
> Duncan
> P4 1.9GHZ
> 1 Gb RAM
> nVidia GeForce4 MX 440 [4.5.2.3]
> Win X/P (home) sp1[all updates]
> Inv7sp1
> NSW2003(incl.NAV2003)+NIS2003 [all updates]
> "Richard Hinterhoeller" wrote in message
> news:1BBC840618A3449F12D36FC3A5C93DB0@in.WebX.maYIadrTaRb...
> > I agree on both counts, although I've found that to some degree, a
> > similar feature exists.
> > For example, if you want to draw disjointed lines in a sketch, draw the
> > first line, press enter and you can now draw another line elsewhere.
> > As for co-ordinates, I can get a sense of proportion based on the sketch
> > grid. For example, my imperial template is set up with minor grid lines
> > set to inches and major to feet.
> > Richard
> > JDMATHER wrote:
> > > As noted above look in the lower right hand corner as you are
sketching.
> > > By the way I had to fire up Inventor and check if the precise input
tool
> > > bar needed to be loaded to see the coordinates (it doesn't) because I
> > > haven't used coordinates since my first month on Inventor. One of my
> > > early complaints was no direct distance entry ala ACAD or spacebar to
> > > repeat last command. Somehow I no longer wish for direct distance
entry
> > > or even notice coordinates, but I still often wish for spacebar
repeat.
