Whenever I get to the section to install cooling channels on the mold design in Inventor 2014, after I click "APPLY", Inventor 2014 immediately shows the message "Not Responding". I have done this dection of the tutorial a number of times, but always get the same error. My O/S is Windows 7 Ultimate with an nVidea GTX570 card, so I wouldn't think there is aproblem with my equipment. Has anyone else experienced this problem? If so, do you have a fix? Thanks!
Hello Sheriff12,
I have the same problem. Did you got to fix this problem?
Regards.
I found that the easiest way to fix just about any problem with Inventor 2014 or any Autodesk program is to go to your Control Panel and reinstall the program. It may seem like a drastic way to do it, but it usually works.
Well, it seems it doesn´t work for my computer but any ways I tried to edid the mold on other computer and worked with no problems.
Both computers have all service pack up to date but the problematic one has installed some other NON-Autodesk CAD software. Not strage to me to have problems because of NetFramework versions and stuff like that.
