Inventor Forum
Converting a surface into a solid body
7 REPLIES 7
Message 1 of 8
collinseric
8038 Views, 7 Replies
I am trying to convert this composite surface into a single solid body, however when I try to stich the surfaces in the construction environment it always crashes. I have also tried edditing the STEP file import options but it still always opens as a composite surface.
Eric
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: collinseric
No file attached?
Message 3 of 8
collinseric
in reply to: JDMather
I'm having touble uploading it... says the file size is too large... already compressd it in a zip. Solutions?
Message 4 of 8
JDMather
Depends on where you have it.
In Inventor?
Drag the Red End of Part marker above the Composite body and nothing in Construction (or Repair) environment.
Save the file in a rolled up state and then zip.
If still larger than 1.5 meg the limit is 10Meg over here http://www.augi.com
Message 5 of 8
collinseric
Message 6 of 8
JDMather
The most obvious question - Why would you even need that as solids?  Wouldn't you simply purchase from the company?
Message 7 of 8
WHolzwarth
This seems to be a derived part from a SWX 2010 assembly, as can be seen in the translation report.
I've seen several similar parts, and most of them had lots of missing or distorted faces. SWX derived parts seem to be only minor quality.
With lots of spare time and some knowledge, you can rebuild these imports. But that's no fun.
Walter
Walter Holzwarth
Message 8 of 8
JDMather
If you need to include in assembly drawing - simply tell Inventor to include surfaces.
If you want it to "appear" solid - right click and turn off Translucent.
If you reall want to take the time to convert to solids you will need to create Groups in Repair (Construction) environment and isolate the different parts into different groups.  Patch the missing surfaces, stitch and promote. (an all day job on this assembly)
