I have a file "Crankshaft" which I downloaded from internet. The file is not created by Inventor software but imported into Inventor and made some amendment.
When I created section view in *.idw. The Crankshaft cannot show the hatching line. I do not want to spend time to add the hatch line manually or recreate the file by using Inventor software.
Anybody can help me to convert it to Inventor file and able to show the hatching line in sectional view. The file is attached below.
Solved by JDMather. Go to Solution.
Solved by AustinLiu. Go to Solution.
Hi
See step file
the base solid had some error (i work with 2011)
I can create the hatching lines successfully.
Have you checked on Hatching in Drawing View? Please refer to attached snapshot.
Btw, for the data error as Yannick mentioned, you can copy the data to Construction Environment and repair it to clean with Refit Tool directly.
Dear Liu and Yannick
Thanks for your reply. I am using IV2010 so I cannot open the file post by liu. I tried to STITCH the surface, but I cannot do that. Please see the attached screen print.
@lis_wang wrote:Dear Liu and Yannick
Thanks for your reply. I am using IV2010 so I cannot open the file post by liu. I tried to STITCH the surface, but I cannot do that....
See this http://au.autodesk.com/?nd=class&session_id=3056
You can repair it easily after you study JD's materials.
Have a try. 🙂
Btw, have you got your hatching line now?
Not yet now as I am quite busy. I have not yet take a look JD's training video today. I will try tonight or tomorrw. I am using IV2010 and cannot open your file. I will try myself.
Thanks&Rds
@lis_wang wrote:Not yet now as I am quite busy. I have not yet take a look JD's training video today. I will try tonight or tomorrw. I am using IV2010 and cannot open your file. I will try myself.
Thanks&Rds
There is also a print document at the link I provided that goes along with the recording. Pay particular attention to Problem 6 pgs 23-25 for this particular problem. Read/watch the whole thing as I might have covered stuff earlier that is assumed by pg 23, but I think that problem most closely represents your part.
Dear JD
After watching your video, I solved my problem.
Can I download your video, notes and datafiles? I do not have user ID to sign in.
My email address is: wang_jianwu@ite.edu.sg
Thanks for solving my problem.
@lis_wang wrote:I do not have user ID to sign in.
You can create a free account on http://au.autodesk.com to gain free access to the materials.
