Hy. I wish to find out if it's possible to convert this solid/sketch to sheet metal and apply a flange to it's edge.. Any tips are welcome!
Autodesk Inventor Professional 2014
Solved by JDMather. Go to Solution.
Solved by blair. Go to Solution.
well..that's the scratch.. 1.5mm thickness..Inventor it's able to make a flange on that curved surface and later give me the flatten?
can't find a solution 😞
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-DFEBDA33-7AAD-41FE-8064-63306842A0A5
Here it is. IV 2010 file. But I would check manually that the flat pattern dimensions are correct.
Igor.
@Secttor wrote:Hy. I wish to find out if it's possible to convert this solid/sketch to sheet metal and apply a flange to it's edge.. Any tips are welcome!
here you go
well..thanks for your quick suggestions but If I need those flanged sides to be cut like this? Both? (mirror or?)..
What about just mirroring what Blair posted? (attached)
Ok..saw that you guys succeed..saw your files but cannot get to the next point on my own.. here I am with my project. I should use contour roll for my rounded portion but..
Well..succeed for the first part.. now I must "Extrude" under Sheet-Metal the straight-parts.. any tips? Finally all this half will be mirrored to obtain the full part..
Thanks.. here it is.. but how do I rise up those to edges ?
Attach ipt file here.
Well..here it is but I also want to learn such tricks ..
First thing I noticed is that you did not fully constraint Sketch1 and use obvious symmetry about the origin.
Second - I would not use Extrude in a sheet metal part (as a beginner).
Third - when I post a solution to your problem - you should be able to reverse engineer the Feature Tree in the browser.
While I work up a solution, you might go through these -
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
