Inventor Forum
Convert Inventor assembly file to FBX file
11 REPLIES 11
Message 1 of 12
lis_wang
15115 Views, 11 Replies
How to convert Inventor assembly file to FBX file?
11 REPLIES 11
Message 2 of 12
KevinLi-Autodesk
in reply to: lis_wang
Hi lis_wang,
Currently Inventor version has no ability to convert its assembly to FBX format directly, but this is a user requirement which we will consider.
Workaround I thought in my mind is to use Inventor to export the assembly to IGES/STEP, open IGES/STEP in 3D Max or Maya, then export it to FBX format.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 3 of 12
lis_wang
in reply to: KevinLi-Autodesk
If I converted the assembly file into step file, then all the constrains will be gone.
Message 4 of 12
DarrenP
no matter what you do your going to lose the inventor contraints
you have to recontrain using the 3ds max tools
DarrenP
Message 5 of 12
lis_wang
in reply to: DarrenP
Thanks. I will constrain my assembly file in 3dMax
Message 6 of 12
cwhetten
Is it necessary to convert from Inventor to IGES/STEP before opening in 3dsmax?  What's wrong with opening in 3dsmax directly from the Inventor files?
Cameron Whetten
Inventor 2014
Message 7 of 12
KevinLi-Autodesk
in reply to: cwhetten
Yeah! 3DS Max can directly import the Inventor assembly file, then export it to FBX.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 8 of 12
nithin9JMXC
I was trying to export fbx file from inventor professional 2022. I tried installing autodesk inventor fbx tool but it shows 3Ds max 2018.4 required to run the program. Is there any way to export fbx file using inventor?
Message 9 of 12
WHolzwarth
in reply to: nithin9JMXC
If you have access to Fusion 360, FBX export is possible from there, after opening Inventor files or a STEP from there.
I'd suggest STEP, because the whole assembly is placed in a single file.
On the other hand: What's the benefit of FBX? It's a mesh format, similar as STL or OBJ.
Walter Holzwarth
Message 10 of 12
nithin9JMXC
I have the Meta (Facebook) Oculus Quest 2 VR goggles which works on this 3D platform
Message 11 of 12
nithin9JMXC
in reply to: WHolzwarth
Thanks Walter Holzwarth for the solution.
Message 12 of 12
WHolzwarth
I don't have an Oculus Quest 2 or any other VR device, because of minor view capability on one eye.
But I could see, that importing OBJ files seems to be possible, too. Perhaps a more straightforward way for Inventor data.
Walter Holzwarth
