Hey everybody,
Here is the problem we are facing.
From all our parts of an assembly we made 1 IDW with multiple sheets. Now we want to convert this IDW to DWG and in such a way that we have one DWG file for all sheet.
Solved by Cadmanto. Go to Solution.
Welcome to the forum.
Just call up your .idw file and do a file save as copy
Then select Inventor drawing as the file type.
This will keep all of your sheets in tact.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
