I have an helical screw located in a half-drum.
The half-drum is grounded and the screw is constrained axis to axis to it. I can rotate the screw WRT the half-drum.
I want to be able to do so in a controlled manner, i.e. to be able to call for a rotation of, say, 35 degrees.
I am using Inventor 2015. Can I control rotation like that?
Solved by JDMather. Go to Solution.
Drive Constraint of an Angle Constraint
or
if you have Inventor Professional
use the Input Grapher in Dynamic Simulation.
