Inventor Forum
Contour Flange on tangential arcs
3 REPLIES 3
JJarbeau
594 Views, 3 Replies
Hello Everyone
I have sketched a fan casing which consists of a series of tangential arcs. The sketch is fully defined but when I try to use "Contour Flange" I get the following error:
Sheet Metal: Contour Flange Creation failed.
19-3-101-26-2.ipt: Errors occurred during update
The attempted operation did not produce a meaningful result. Try with different inputs.
Try decreasing bend radius
Feature Compute failed.
My guess is the end points of the arcs are not defined correctly but I do not know how to fix. I have attached the file.
Please help
Jeff Jarbeau
3 REPLIES 3
CCarreiras
in reply to: JJarbeau
Hi!
The main question is, this is not a "series of tangential arcs".
The tables which you are taking the values have a lot of approximations. I know that, I have working with some ventilators.
The workaround is (2 options):
1)  delete some dimentions and give the tangency constrain to the interior arcs. The diameter Dimensions will change so much. I think it's not a problem for the ventilator's work. If so...
2) Create little arcs between all interior arcs: split, construction. See the file i attached, you will understand better.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
JJarbeau
I kind of thought that was the problem. Struggled for hours to try and fix.
Thank you kindly for the help
Jeff
JJarbeau
in reply to: CCarreiras
I have stumbled upon a new wat to make the curves tangent. Creat a small space between the two curves (as per your suggestion) and under the spline drop-down there is a choice of "bridge curve". Select the two curves and dimension.
