Is there a patch or fix for the missing 2500 lb slip on flanges in the content center?
Hello and welcome.
I would say no patch is my best guess. As big as the CC library is, they didn't get everything that all of us could want or need. Even some things that seem like they SHOULD be in there, just aren't. Fortunately, if you are working with a Read/Write library, you can populate the CC with whatever you need by either creating, authoring and publishing an ipart... or by copying and modifying an existing CC family. In some cases, you may be able to find certain things online. In the case of this flange, it might be easiest to copy one that is close, and edit the family table for those dimensions or characteristics that are different.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Maybe have a peek at ASME B16.5 and a few vendor catalogs.
I have a 2500LBS Slip on ran with an excel spread sheet can be made into a ipart and published to CC.
I will upload if you need when I get home I did not bring my drive to clients..
