Ive made a little mistake while making a content center part.
Is there anyway to edit the Ipart that i published into the content center? there is a custom property in there that i would like to have deleted.
Solved by cbenner. Go to Solution.
From Inventor, do an "Open from Content Center". Open the published item in question and (if there is more than one) pick a size. Make sure you open it "As Custom", so you can save it someplace to work on it.
Once the part is open, make whatever changes you need to. Save the part. Go back to Content Center editor, and find the part family. Right click and select "Replace Family Template". Find and select the part file you just modified. It should replace the CC part family model with the part you've just modified.
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
