When placing parts from content centre they all seem ok except Angle.
Placing the angle is not a major problem, but when opened to edit (putting holes etc) it is so slow.
Slow when creating sketch on face, when trying to add dimensions etc, even slow opening and closing.
Like i said working with other parts seems ok, just angle the problem.
Any suggestions?
Andy,
What are your system specs? What version are you running?
Doest this only happen with one assembly or does it happen regardless of how simple/complicated the assembly is.
Are you using Vault by any chance?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Running Inventor 2014.
This was a problem prior to and after installing SP1 so that is not an issue or help.
yes we are using vault
Slow when the part is open independant of an assembly (assemly sizes vary)
