Inventor Forum
Content Center parts don't show in part-generators
5 REPLIES 5
miechh
752 Views, 5 Replies
For some reason when I start either the bolted connection generator or the shaft generator, the content center parts don't show up if I select "modify" to change the parts. For example: I wanted to create an axle with a retaining-ring-groove. I created the axle, and under Features I selected Retaining Ring.
Then a dialog shows up with some standard dimensions, and on the right under "Position" it says "ASME B 27.7M". When I click here, an empty dialogbox shows with filter "All" activated.Shaft_Generator_Contentcenter_Empty.png
It should show all retaining rings available in the content center. The strange thing however is that when I exit this function and start the ordinary "Place from Content Center" command, I can see all retaining rings that are available (see pictures).
The same thing occurs when using the bolted connection generator. What's wrong and, more important, how can I solve this problem?
Thanks in advance for your tips and solutions.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
5 REPLIES 5
alessandro.gasso
in reply to: miechh
I suppose you retrieve the Content Center parts from a Vault Server.
If this is the case, there is an hot fix for the Vault Server that solves the problem, as explained in the blog post below.
http://beinginventive.typepad.com/being-inventive/2011/08/content-center-elements-not-available-when...
I hope it helps.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
miechh
in reply to: miechh
Alessandro, thanks! I applied the hotfix, and it works!
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
skylinejeff
in reply to: miechh
Resurrecting an old one...
I am having an identical issue, but I do not use Vault.  My content center is all local.
Using IV pro 2016 with all current updates as of two weeks ago.
Any hotfixes for this one?
J
What happens if you place from content center in your assembly, do you see the components in your CC, or is it blank too?
Mark Lancaster
All of my retaining rings are accessible through CC.
