Inventor General Discussion
Active Member
dshuping
Message 1 of 7 (337 Views)
Content Center Files
337 Views, 6 Replies
01-31-2013 06:24 AM
   I am using Inventor 2010, and just gone through the install program to add in content center files.   It installed 11 IDCL files and 1 IDZ file. I copied all these files to "C:\Documents and Settings\dshupin1\My Documents\inventor\Content Center Files\R2010".   Now, when I try to open something from my content center, I get a "Failed to open document" error, then another error that the file is not valid for placement.
Thanks in advance for any and all help.
Cadmanto
Message 2 of 7 (333 Views)
Re: Content Center Files
01-31-2013 06:53 AM in reply to: dshuping
Is your path setup correctly in your master project file for the CC?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Active Member
dshuping
Message 3 of 7 (311 Views)
02-01-2013 05:21 AM in reply to: Cadmanto
Thanks for the reply. I'm fairly new to Inventor, without the benefit of other users in the company. I know how to create projects, but I'm not sure what you mean by Master Project. When my projects come up, I have all the ones I have created plus a Default and several others that were created at installation. I'm considering re-installing Inventor, now that I have learned lots of shortcuts and options. Thanks [cid:image003.jpg@01CE0055.0B60B370] Donald B. Shuping Electronics Technician Industrial Microwave Systems 3000 Perimeter Park Drive Morrisville, North Carolina 27560 Office (919) 371-1396 Mobile (504) 259-9495 Fax (919) 990-9596
Cadmanto
Message 4 of 7 (297 Views)
02-01-2013 08:11 AM in reply to: dshuping
I was talking about when you select the "I" in the upper left corner and "Manage" then Projects, you should see this dialog.
Just make sure the CC is pointing to the correct folder where you are trying to find these files.
Best Regards,
Scott McFadden
Active Member
dshuping
Message 5 of 7 (293 Views)
02-01-2013 10:05 AM in reply to: Cadmanto
OK, I understand, but under a specific project, if I create a new assembly, then try to place something from the content center, all the .IDD files show up. I try to select one of these, and get the error messages I described. Do I need to do some kind of translation to get them in a form Inventor would recognize? [cid:image002.jpg@01CE007C.AD6AB7C0] Donald B. Shuping Electronics Technician Industrial Microwave Systems 3000 Perimeter Park Drive Morrisville, North Carolina 27560 Office (919) 371-1396 Mobile (504) 259-9495 Fax (919) 990-9596
*Pro
sbixler
Message 6 of 7 (273 Views)
02-02-2013 04:28 PM in reply to: dshuping
What Scott is showing you is where content is placed from the library when used.  I think what you're asking about is where the libraries are placed.  In Application Options > Content Center tab, check the location, and change it to match yours if necessary.  The open the project editor and click the drop-down menu in the lower right corner just above the Done button, then click the Configure Content Center button (the only one in the list...?).  This will allow you to choose which libraries you want available to this project.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Active Member
dshuping
Message 7 of 7 (255 Views)
02-04-2013 04:11 AM in reply to: sbixler
Thanks to all who replied. I tried everything to no avail. I deleted Inventor and re-installed, still no luck. The second time I deleted Inventor, I deleted all files and folders that had "Inventor in the title. When I re-loaded, everything worked fine. It found the content center files, migrated them on it's on, and everything works. Thanks again [cid:image003.jpg@01CE02A6.CEF013F0] Donald B. Shuping Electronics Technician Industrial Microwave Systems 3000 Perimeter Park Drive Morrisville, North Carolina 27560 Office (919) 371-1396 Mobile (504) 259-9495 Fax (919) 990-9596
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
