I have created a new item in content center in my personnel library. Regarding that i have a quick question.
When i am creating a new item in content center its creating *.ipt file somewhere ? If so from which location i can open the part file ?
Please help....
Solved by Cadmanto. Go to Solution.
When you publish the file to the CC it is not copying the .ipt persa. It is creating the recipe
needed to create and insert the part into an assembly. I believe it is creating the HTML code when publishing.
If you want to edit it or change it you are going to have to delete it out of the CC, change the one
on your local then republish it back to CC.
Thanks scott ...
You're welcome. Glad it worked out for you.
