Inventor Forum
Constraint locks object
14 REPLIES 14
Message 1 of 15
JoelMckone
9336 Views, 14 Replies
When I add a single constraint to an object it locks in into position.  Also, non-related constraints are causing error messages (for example inserting a screw is causing an error in a flush constraint in non-related parts).  I had issues with this in the previous release of Inventor but have not had a problem with 2011.  This problem just occurred today - attempts to delete problem parts and rebuild the assembly does not resolve the issue.
Any suggestions as to the problem?
Tags (1)
14 REPLIES 14
Message 2 of 15
dan_inv09
in reply to: JoelMckone
Suggestions:
1. Too much adaptivity - turn as much adaptivity as possible off (unless the latest constraint is supposed to affect it, it should not be adaptive at this time.)
2. Daisy chained assembly - Let's say part A is grounded and part B is constrained to it, then part C is constrained only to B, and D only to C etc. It's got to figure out each constraint and how it affects each other constraint and after a while it just gives up and parts you place don't want to move. Temporarily grounding some stuff near where the new stuff is going sometimes got it to work when I used to have this problem.
Message 3 of 15
blair
Look for a bad contraint somewhere in your assembly. It could be in a sub-assembly as well.
Delta Tau Chi ΔΤΧ
Message 4 of 15
JoelMckone
Rather than chase through all the constraints I have decided to rebuild the object (sliding window) in a new assembly (I changed the frame parts to a new profile which created the constraint crash).  Now if I add a constraint I cannot move the object, however additional constraints will work to properly align the object.  I seem to remember this happening before as well and it was a matter of a setting being changed but of coarse I cannot remember where of if this was in fact the problem. Have you experienced this issue?
Tags (1)
Message 5 of 15
JDMather
Zip and attach your assembly here.
The CADWhisperer YouTube Channel
Message 6 of 15
JoelMckone
It won't let me send the file at 3.2 MB, I am trying to eliminate as much stuff as possible but still keep enough stuff to demonstrate the problem.
Message 7 of 15
JDMather
Roll up the EOPs to make the ipts smaller before zipping.
I suspect you should be able to isolate the problem to two or three parts in the assembly.
Message 8 of 15
JoelMckone
Attached file.  Oddly enough I can't even get the constraints to work on these three pieces even though I had assembled it earlier in the day.  All that is missing is a flush constraint so that all the parts line up.
This project seems to be the only one that will not work.  Other window (larger) window drawings still work fine.
Message 9 of 15
blair
Works fine here
Delta Tau Chi ΔΤΧ
Message 10 of 15
JoelMckone
Problem seems to be rooted in bad frame drawings at the cad level.  I redid the vendor drawings by tracing the section outline using P-lines.  When these were extruded and imported into the assembly all the previous issues vanished and the window will now function properly.
Message 11 of 15
maximebouch
Better just delete all constraints then
guys there is a common language we can use
Message 12 of 15
Walenciak_Ross
Sounds great...
but I have no idea what that means.
Message 13 of 15
Hi! Joe found the workflow to free up the components. It sounds like there was some sort of corruption in his frame subassembly (skeletal). Then he recreated and and it helped resolve the issue.
I am not sure if your issue is exactly the same as his. This is a very old thread. The issue may not be relevant now. Could you start a new thread and describe the issue you are seeing (attach the files if possible)? We can take a look to see how we can help you better.
Many thanks!
Software Test Engineer
Message 14 of 15
jdg072
in reply to: dan_inv09
  @dan_inv09
I  tought this was the only correct way to constrain things. What if you consrtain parts just "in the wild" instead of "to it's previous and next part" Who is (maybe except yourself) ever going to find the constrains if the assembly needs modification.
Message 15 of 15
dan_inv09
in reply to: jdg072
Did you read the rest of that at all?
Yes, that is the correct way to do it, but when you've got 10 or 20 things in a row and any movement at all in any of them means your computer has to recalculate the locations of every single one of them Inventor is going to bog down.
If you temporarily ground a portion of it that shouldn't be moving it should allow you to keep working.
[Personally, I would see it as an opportunity to remind your boss that the engineering department needs regular upgrades to its equipment, and minimum requirements just doesn't cut it. That might take at least a few days if you think that's the only solution (plus, it's not guaranteed to be enough).]
Of course you could have the OP's problem where one of the parts is screwy. You don't have anything translated from some other software or anything, do you?
