Why does this not work? Open up the flexible limits.iam. Expand the last part 300-4474_57 to see the constraints. Change the Mate:52 from -8 to -10 and watch how the assembly updates. That is how I want it to react with limits set for the cylinders. Now close down the assembly without saving. Open up the 107400_SKS.iam. Expand the last part to see the constraints. Suppress Mate:1 and unsupress the Insert:1 +/-. Save the file and then open the flexible limits.iam again and change the -8 to -10 and it fails. Note: only the top level is attached. I will reply to this with the other files needed.
Sorry for the confusion. But even after changing the upper limit to 4 it is still doing it. Can someone look at this afterall.
Shastu,
What version of Inventor are you using for this dataset?
Jan
