Several ways to tackle this problem.
You could do as you say and reconstrain the rectangle to the origin. To do
this project the center point onto the sketch and by using construction
geometry and a few dims constraint the middle of the rectangle to the
projected point.
Or you could just make 2 planes on the rectangle itself by selecting 2
parallel surfaces. This will make a workplane that bisects these surfaces
and always remains in the middle regardless of how the rectangle changes
sizes.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"drennox" wrote in message
news:f17b82d.-1@WebX.maYIadrTaRb...
> How can I constrain sketch geometry to the sketch origin?
> The situation is that I want to constrain a circular shaft to be in the
centre of a rectangular plate such that it remains in the centre regardless
of changes to size of the plate. I reckon I need to constrain the planes of
the plate to the planes of the shaft but that requires that the geometry of
the plate be constrained to the origin of the sketch used to create it.
> David Rennox
