Maybe I am just stupid and forgot basic math but can anyone tell me why i am not allowed to use a concentric constraint on both circles, geometrically the distances add up (and yes i used the trig as well to see and 1.264 is the distance) Any help would be appreciated
Solved by JDMather. Go to Solution.
The holes are different distances apart.
1.263984276 vs 1.264
BTW - I think you are doing wayyy too much work. I would use = (equal) constraints (or some other method) rather than repeating dimensions and use Hole features rather than extruded circles.
Ahh thank you! I have been getting so frustrated! And I have to build it like this as it is a transmission tower. The beams are all reused multiple times for the truss and i have to run full stress analysis on it. As for the hole feature, when i learned inventor in college that didn't exist so i'm too used to extrusions 😛 I got the dimension fixed though, thank you!
