I have created a iMate with min and max values - Call it "TEST". I have it working as an iMate so that it mates up automatically when i insert parts into an assembly. I can drag the part through my defined min/max range.
I want to apply more than one constraint upon part insertion, so I guess I need to set up a Composite iMate.
As soon as I add my "TEST" iMate to a Composite, the min/max stops working and I am locked in to whatever the offset was in the "TEST" iMate definition.
Am I doing something wrong, or is this how it's supposed to not work?
Iqbal.
IV2012/Win7/Vault Collab
I just tried to place comp with composite iMate that contains min/max. It worked on my computer.
If you still can't create iMate result, could you attach your dataset so I can take a look what's wrong?
Robert
