Inventor Forum
Component pattern about mid point?
9 REPLIES 9
Message 1 of 10
600 Views, 9 Replies
Is this possible? ie. have a pattern go in both directions like in part file?
9 REPLIES 9
Message 2 of 10
swalton
Not yet. (IV 2014)
There are several posts in the Ideastation about this.
See:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Allow-Symmetric-Component-Patterns-in-Assembly-En...
for the most recent one.  It lists all the related posts in the comments.  The parent is marked Accepted, but I don't know how long it takes a post to go from Accepted to available in the software.
Add a kudos if you think this is important.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 3 of 10
in reply to: swalton
Thanks for the reply.
Are there any work arounds? Its hard to use a pattern from one of the parts without creating something that will physically appear.
Message 4 of 10
jletcher
Not true...
It will as long as it is a feature Pattern Select from a part that has it going both ways..
LOL
Message 5 of 10
jletcher
Use surface in part, pattern and turn off viz..
 Works great.......
Message 6 of 10
mcgyvr
Workaround is here.. (see the accepted solution by cwhetten)
http://forums.autodesk.com/t5/Inventor-General/Bi-Directional-Patterning/m-p/3687130#M453320
Message 7 of 10
in reply to: jletcher
Worked! Bit messy but allows me to do what i want.
Cheers.
Message 8 of 10
mcgyvr
Cheers.
Careful.. watch the bom count with that workaround.. It creates more parts that it should be as you are duplicating the original
Message 9 of 10
LT.Rusty
in reply to: mcgyvr
@mcgyvr wrote:
Cheers.
Yep.  Gotta make sure to remember to suppress the extra occurrence when you're done with the pattern.
Rusty
Message 10 of 10
HarryP108
in reply to: LT.Rusty
The bane of my existance component patterns - that and mirrors. All this garbage about workarounds, suppressing occurrences, watching BOM counts etc.
All the while the opposition software i.e. Solidworks, patterns and mirrors work seamlessy...
Let's all hope for small miracles in the next release.
Regards.
Inventor Professional.
Windows 10.
