Inventor General Discussion
Active Member
TRYoung71
Message 1 of 8 (326 Views)
Component drop-down in Format Text dialogue box not producing intended results
326 Views, 7 Replies
11-27-2013 07:51 AM
In an .idw environment, I have multiple models displayed.
I am trying to create simple text labels for each model using text, modifying each one so that it will display the part number and the revision level by using the "Component" drop down box and assigning the proper "Type" and "Property", then using the "Add Text Parameter" button to place the fields into the text box.
This works as intended for the first model that I created a view for.  However, it will not work for each successive model; the text will revert to the part number and revision level of the first model that was brought into the .idw environment, even if I change the target component in the "Component" drop-down box.
In the .jpg that I have attached, you can see that I have 035-14218 selected in the "Component" drop-down.  This is the initial model that I brought into the .idw. and the resulting text is correct.
Is this a bug, or is there something else that I need to do that I am missing?
Thank you.
Windows 7 Pro, SP1
Inventor 2012 SP1
Due to the nature of our business, I am not permitted to attach any files showing models or .idw environments of any actual work-related components.
*Pro
jletcher
Message 2 of 8 (314 Views)
Re: Component drop-down in Format Text dialogue box not producing intended resul
11-27-2013 08:04 AM in reply to: TRYoung71
Are these assemblies or parts?
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Active Member
TRYoung71
Message 3 of 8 (312 Views)
11-27-2013 08:05 AM in reply to: jletcher
These are assemblies.
Windows 7 Pro, SP1
Inventor 2012 SP1
*Pro
jletcher
Message 4 of 8 (293 Views)
11-27-2013 09:10 AM in reply to: TRYoung71
  Seeing you have assemblies you also can't use a symbol.
  You would have to right a VBA or ilogic to get it to work. I am a bit busy today but if someone does not help you on this I will when I am done.
You could do a search to see if some has done this already and I believe it was..
It is also a item in idea section you can vote for it to be added..
I will find links later if no one helps you..
 Sorry..
James Letcher
*Pro
jletcher
Message 5 of 8 (291 Views)
11-27-2013 09:14 AM in reply to: TRYoung71
Here I did a search this is what I found you may have to change it up or search for more..
http://forums.autodesk.com/t5/Inventor-Customization/ilogic-code-to-change-View-Label-Text/m-p/36251...
James Letcher
*Pro
jletcher
Message 6 of 8 (288 Views)
11-27-2013 09:18 AM in reply to: TRYoung71
This may be better
http://forums.autodesk.com/t5/Inventor-Customization/Custom-user-properties-in-view-label-of-drawing...
James Letcher
*Pro
jletcher
Message 7 of 8 (286 Views)
11-27-2013 09:21 AM in reply to: jletcher
P.S.
  Please give Curtis_Waguespack the thank you. He did all the work and is a very nice guy..
 You can kudos me for the help if you wish but he gets all credit..
James Letcher
Active Member
TRYoung71
Message 8 of 8 (280 Views)
11-27-2013 09:41 AM in reply to: jletcher
Windows 7 Pro, SP1
Inventor 2012 SP1
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
