Inventor General Discussion
*Expert Elite*
Cadmanto
Message 1 of 14 (640 Views)
Component Visibility States in Drawings
640 Views, 13 Replies
02-18-2013 08:28 AM
Does anyone know why the visibility cannot be toggled on/off in drawings?  Why the visibility selection is greyed out?
Specifically when it comes to patterns.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
*Pro
ampster
Message 2 of 14 (630 Views)
Re: Component Visibility States in Drawings
02-18-2013 08:51 AM in reply to: Cadmanto
works for assemblies in 2011.   You have to expand the pattern and select the actual part, not the "Element:x" entry.
Valued Mentor
mpatchus
Message 3 of 14 (622 Views)
02-18-2013 09:06 AM in reply to: Cadmanto
Check your view properties.
If the view Representation is set to ASSOCIATIVE, you cannot change the visibility of components in the view.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
*Expert Elite*
Cadmanto
Message 4 of 14 (603 Views)
02-18-2013 10:34 AM in reply to: ampster
Yes, it works in my 2012 assembly as well.  I am talking about in the drawing.  :smileyhappy:
Best Regards,
Scott McFadden
*Expert Elite*
Cadmanto
Message 5 of 14 (602 Views)
02-18-2013 10:36 AM in reply to: mpatchus
Yes, you are right.  I forgot about the associativity selection for it being greyed out.
But, why can't you select the patterns to change the visibility?
Best Regards,
Scott McFadden
*Pro
ampster
Message 6 of 14 (587 Views)
02-18-2013 12:03 PM in reply to: Cadmanto
That screenshot is from the drawing :smileywink:
my bad for cutting off the top!
*Expert Elite*
Cadmanto
Message 7 of 14 (576 Views)
02-18-2013 12:58 PM in reply to: ampster
Oh, no problomo!!!  :smileytongue:
I can do that as well.  Meaning treeing out the pattern to show the individual components and turning off the visibility there.  Now why can't you just turn off the visibility of the entire pattern?  I have a case where my assembly has a bunch of patterns and to do the individual components is time consuming.  It would be worlds easier to just turn off the pattern.
Best Regards,
Scott McFadden
*Pro
ampster
Message 8 of 14 (569 Views)
02-18-2013 01:13 PM in reply to: Cadmanto
Entire patterns, ahhh!  Good question!
And another mistake I made early this morning was overlooking "component" patterns and just assumed "patterns" hence the reason I added "assemblies" to my 1st post!
Was lacking caffeine this morning!
If it helps, you can expand all the components (have to actually), then highlight the 1st component then press and hold the ctrl key while clicking on the last component.  This will highlight all components and allow you to turn vis off.
Still, too much work to do that!
Valued Contributor
VdVeek
Message 9 of 14 (564 Views)
02-18-2013 01:23 PM in reply to: Cadmanto
Create a new representation View in the assembly file where you hide the patterns and then change in the drawing your view to the special made Representation view.
Rob.
Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
*Expert Elite*
Cadmanto
Message 10 of 14 (519 Views)
02-25-2013 08:06 AM in reply to: ampster
How is your caffine level today?  :smileyvery-happy:
I could do that and I know that is a way to do it, but it is a pain and very time consuming when you have hundreds of (specifically) hardware parts.
Like I said, it would be a whole lot simpler to do it at the parent pattern level.
Best Regards,
Scott McFadden
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
