Using Inventor 2014 and Vault Basic 2014. It was working this morning but now when Invnetor is opened it automatically logs into Vault and says it is successful but the open from vault icon is greyed out. Similarly when opening a drawing from the vault it used to automatically run and open inventor but now seems to lack the connection. Even when manually opening a drawing that is in the vault by downloading it from the browser and then opening in inventor there is no Vault tab on the browser and all Vault commands except "log out" are greyed out. Any ideas on how to fix?? I wasn't sure who would have any ideas so I posted in both the Inventor group because I think it has something to do with the add-in as well as the Vault group. Any ideas would be appreciated. Thanks!
Solved by MingweiGao. Go to Solution.
Hello, it seems you changed your project file to Single User, not a Vault project. Can you have a check about your project file?
Hey thanks for the response! It was actually happening on a coworker's computer and I finally noticed that the project file had somehow changed a bit after posting the question here and forgot to take it down.
