Inventor Forum
Combining parts into one
7 REPLIES 7
Message 1 of 8
feldwill
4284 Views, 7 Replies
I have made one part out of 4 different sections. And now I'm trying to combine it into one solid. My thought process was: if I make a derived part out of them it'll automatically make it a solid part. But I'm still having separate surfaces where two should have been united.
What is the procedure for getting this accomplished.
Thank You
  William
7 REPLIES 7
Message 2 of 8
Accudyne1
in reply to: feldwill
Can you post a picture of your failed result?
What version inventor are you running?
Tony
Message 3 of 8
Accudyne1
I am using 2012...this is the button you need to select to merge seams in a derived component...
Message 4 of 8
feldwill
in reply to: Accudyne1
See attached screens.
Seems like I'm doing the same thing. The joint in blue circle joined like it shout, but in red stayed as 2 separate surfaces.
W
Message 5 of 8
JDMather
Try Delete Face with Heal and select the two faces.
Are you sure both of those faces are the same?
The CADWhisperer YouTube Channel
Message 6 of 8
Accudyne1
That is odd...could you post the part maybe? I have to run out for a bit, but if no one else has looked I will take a look after lunch...
Good luck
Tony
Message 7 of 8
feldwill
I'm using 2012. The part is a bit sensitive to post ipt's. But at least I know I was on the right track creating the part.
The spiral was created as a 36-section loft, so it could be that one of the surfaces is not a perfect geometric shape. I'm thinking that 2 surfaces that meet are good, but the ID of the spiral is not a perfect circle.
Let me play around with geometry and "healing" surfaces.
I'll keep you posted.
Thanks for validating my technique.
  Regards
W
Message 8 of 8
Accudyne1
No problem, good luck.  Let us know if you figure it out!
Tony
