Yes, I figured that out but is there a way of changing it? I looked in
the registry and on the Microsoft site. Near as I can tell, it is the
default because it starts with the letter C and all the rest use higher
letters in the alphabet. If this is the case, then I would need to
delete all except the one I want because it is the last on the list.
(TechSmith / Camtasia)
To make it more interesting, I just got TechSmith signed off as a
standard for our company (no small feat) and now Inventor can't use it.
Doh!
Sean Dotson wrote:
>Charles I was told that Cinepac is indeed the default codec.
>"Charles Bliss" wrote in message
>news:3DDC5DD6.1090303@cbliss.com...
>>Since I can no longer specify the codec for recording in R6, perhaps
>>someone knows where the default codec is set? On my PC, Inventor seems
>>to be exporting to the "Cinepak Codec by Radius". Wasn't Radius the MAC
>>video company (with financial problems)?
>>Seems to me that there should be a means of setting up this default.
>>When Autodesk goes to "fix" this, I would also like to see a better
>>means of setting up the output frame rate. Another input box in the
>>animation and drive constraint dialogs would suffice.
>>It is currently defaulting to 15 fps which is not what I want either. I
>>have always liked the concept of being able to set the frame rate myself
>>so I can end up with a mathematically predictable animation. Currently
>>I post process all my animations which can become a bit tedious.
