You do use the _ for a proxy path.
See my tutorial on iParts and Project files for more info...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"peichbauer"
wrote in message
news:f1491d8.-1@WebX.maYIadrTaRb...
> I'll try posting again. How do I specify where the location of iparts
should be located. The way we have our system set up we have iparts as
library files (fasteners, purchase parts, etc) on one main network
directory. And with IV5.0 we were having the children of those iparts saved
in the working directory for each project. Now it used to be that you just
put an underscore before the name of the item (i.e. "_fasteners) and then a
location to point IV in the right direction, but now you can't do that under
library file locations. Where do I specify the end location???
> Phil
