Ed G wrote:
> When trying to check in a part I get an option I have never seen yet. The
> saved version of the selected document depends on versions of the following
> files which are not available from the workgroup project. Checking it in
> will require an update and will possibly result in sick constaints and
> unresolved references when opened by someone else from the workgroup. do you
> want to checkin anyway? Then I get a list of three files I have checked
> out. I have saved all these files. I get this message trying to check in all
> three files. I am not sure what to do. Can anyone help me? Thank you
I see it regularly because I check-in assemblies and keep the individual
parts check-out. I have never had more than a minor issue at a later
date. Usually a constraint that required updating, maybe file location
will need to be resolved. We also do not use adaptive parts, so I don't
know how those would behave if you are using any.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4201 drivers
Dell UltraSharp 19" LCD
