Hi Guys,
Since autodesk developers didn't think of the fact that somebody might want to change the material of the bolt or hollow sections when it get's saved in the library, is there any way of changing the default saving path of the content center generated parts? These parts are getting saved in the library folder at the moment so Inventor doesn't allow me to change their material.
Hi Barvas11,
Typically the strategy used for this is to create a "Librarian" project file, that does not include the path of the library set as a library. Then you set that project active and make all of the edits you need to. Then you set your standard project active again to do regular design work.
Will this work for you?
I hope this helps.
Curtis
Thanks for your answer but I have never created a project file before so I don't want to play about with this too much.
Hi Barvas11,
There would be 3 other ways that I can think of to accomplish this.
http://www.inventortales.com/2012/01/creating-custom-content-for-autodesk.html
http://www.inventortales.com/2012/01/creating-custom-content-for-autodesk_11.html
http://www.inventortales.com/2012/01/creating-custom-content-for-autodesk_15.html
http://www.inventortales.com/2012/01/creating-custom-content-for-autodesk_22.html
I hope this helps.
Curtis
Hi
If you don't try you never learn
Press f1 and search "project" all information are in the help for creating new project
shortcut
Hi Curtis,
That's the way I have been doing it but it's a pain..... I was looking for something permanent so that everybody in our office could change materials of the parts without moving them about.
