I have a situation where I just created brand new drawing templates and they have the revision block inthem already. The revision block that comes with Inventor. The vault is driving the revision in the titleblock and when the revision is placed in the revision block it too is linked to the vault. Here in lies the problem. When the drawing is checked into the vault and the lifecycle is changed to "Released" and then back to "WIP" the revision updates. Both in the titleblock (which I want) and in the revision block which I don't want. Not only is it change the revision block, but the last revision posted as per the image below.
What I would like to know is how do I change the property in the settings of the title block to not get it's revision from the vault or allow it to be manually driven?
Solved by Cadmanto. Go to Solution.
Yes,
I'm watching to see what you learn.
Ok, I figured this out. What I did was in the drawing manager
I edited the "REVISION HISTORY"
Which brought up this dialog window and if you select the edit button in the upper left corner it brings up the other dialoag window.
What I did was remove the "REV" property from the right side and added the "ZONE SHEET" property and changed the column header to read "REV". Now this revision block is totally manual with no inputs from the vault.
Just the way we like it.
