Inventor Forum
Changing line weights default for ANSI Style in .IDW?
1 REPLY 1
886 Views, 1 Reply
I'm looking to see if its possible to change the line weights to the ANSI style. I know you can change them per drawing file but I'd like to keep the standard changed as well. What I end up doing is selecting all the layers and dropping them down to .007 line weight in every drawing, which becomes tedious.
I have Inventor 2011 now and if I do make the change to a template is prompts me when I try to make a new idw off that template that its going to change it. Any thoughts?
Thanks guys!
1 REPLY 1
mcgyvr
You typically make the change in the template, then save those changed to your style library. What you seem to have done is simply change them in the template but not push those changes to your style library. After making the changes and exiting from the style manager.. hit the "save" button on (manage tab..Styles and standards section right above update and purge) then when you create a new drawing using that template it will have the correct line weights.
